Exhaust flange bolts
Hi I’m trying to install the exhaust spacers from teraflex. The bolts to remove the flange say 13mm it doesn’t quite fit I try 12mm too small. I have tried the equivalent in stander size still no luck. Anyone else have this issue? Thank you
I just went and checked on mine for you.....and 13mm fits no issue. Is that jeep original to you? Maybe a previous owner rounded em off a bit with a 12-pt socket?
Thanks for checking! I just checked and cleaned them up they had a bunch of dirt on them looks like they may be rounded off some. I got extraction sockets just wanted to use that as a last resort thanks!
This is happening with all vehicles now as the last imperial measurement bastion in the world - USA- is going metric finally. Sad part is everyone has to buy new tools as I believe Jeep JK's are all metric now. I have some BSW (British Standard Whitworth) tools which fit some metric bolts perfectly though. Got them when I started work in 1970.
