evo no limit or jks quick diso
I'm a sahara driver, and went with the teraflex quick discos. That rubi manual e-disco seems nice. My only beef about the rubi disco is that it's possible for the link to hyper extend and come up backwards. I reckon if you like to go fast in the mud it doesn't matter, but if you're going to be throttling over rocks at full droop, I'd go with a clean disconnect.
nope, you aren't wrong, this is exactly why that happens. so long as your links are the correct length, you will not have any problems.
I was looking at it from a straight on point of view. He already has the stock sway bar there. So with the e-disco he would have to uninstall the old, reinstall the new, and get longer links, then add the evo piece. With the JKS all you have to do is put the links in.
That was simply my standpoint. I have not used the rubi e-disco yet but have seen the videos.
EVO NoLimits Manual Rubicon Swaybar Disconnect Price: $89.99 directly from ORE
Rubicon Electronic Disconnect $50 from friend.
Total $139.99 (not including shipping or labor if needed)
JKS Jeep JK Quicker Disconnects 2.5"-6.0" Lift $148.95 from Northridge 4x4 with free shipping. No labor required.
So price wise they are about the same for him. I wish I was able to find a burnt up Rubicon sway bar for that cheap. I've looked, they arent out there.
EVO
If he got new rear links with his lift, the stock rear links are probably the right length and could be used in the front with the modified e disco.
At least that's what was suggested with my lift instructions and the e disco????
I have 2.5 teraflex coil lift, in the rear a got new links and im put my stock rear link in the front, the swaybar look parallel to the ground
