evo c2 axle gusset question?
I'm looking at getting some c2 gussets too beef up my 44
And I know you have to remove everything including the ball joints to prevent damage from the welding.
My question is since I have alloy usa steel sleeved ball joints could I leave the ball joints in when I weld up the gussets without doing any damage?
You will be fine as long as the welds are done slowly and it small amounts at a time. I had mine put on without balljoint removal, and everything is still fine and tight.
im gona replace my factory ones after the welds are done
but I can see your concern if yours are already replaced with better ones / seems most people wet rags and keep them cood during short welds im not sure of the long term success rate of the ball joint but I know factory ones are junk so it wont hurt my feelings to be rid of them
