EVO 1/4 pounder
Old 03-08-2012 | 08:40 AM
CruSHeDJkUR's Avatar
Default EVO 1/4 pounder
Im getting ready to order this bumper for my '12 JKUR....I was wondering how the install was on them? Is there going to be a lot of cutting and grinding? Does it come with the relocation bracket for vacuum pump? Etc..
Thanks!
Old 03-08-2012 | 08:52 AM
Atch's Avatar
I'm also lookin at this bumper but with the stinger, mines '11 but I've seen on here that there is some cutting and grinding required for us newer jk's
Old 03-08-2012 | 09:13 AM
scemracing's Avatar
Yeah I had to trim the crash bar a little to install my Orfab stubby so it needed for most bumpers. it can be done with a dremal or a angle grinder it took 10 min max hit with some paint afterwords you would never know it was done.
Depending on the bumper you may have to relocate the vacuum canister kits are only ~25 bucks or so.
Old 03-08-2012 | 10:49 AM
TRAUMAhead's Avatar
I picked one up last week for my 2010. You chop the crash bar completely off and flip the swaybar motor up. Don't know about the vacuum pump.
Old 03-08-2012 | 11:15 AM
sneck's Avatar
cutting is required. install is not fun. bumper is wicked sexy. highly recommended!
Old 03-08-2012 | 11:23 AM
Atch's Avatar
Got any pics?
Old 03-08-2012 | 11:50 AM
TRAUMAhead's Avatar
Originally Posted by Atch
Got any pics?
Sure if you want a picture of a brown box. Gonna try to get it installed this weekend.
Old 03-08-2012 | 11:51 AM
TRAUMAhead's Avatar
Any tips? Install looked straight foward ..
Old 03-08-2012 | 12:15 PM
sneck's Avatar
are you doing the stinger too? don't skimp on cutting the cross member, and don't forget to repaint it! I think for just installing the bumper itself, it might not be too bad, it was installing the stinger with it that sucked, theres just zero room for tolerance on the holes, so it made for a very tight bit of fitting. those damn spacer plates just were not fun to work with, since you have to plop them on, slide everything on, and hope it was lined up right. if not, remove and try again! since its heavy as hell, just made for a long, heavy install
Old 03-08-2012 | 12:35 PM
TRAUMAhead's Avatar
Bumper for now, adding the stinger in a month or so. Looks like the Stinger will be fun.
