EVAP Canister
Just replaced mine if you have a 4 door you need the higher gallon canister also make sure you still have your vaccum pump if not get it to and the gasket for the pump. I got everything from the dealership they had it in stock.
where is the vacuum pump? all i noticed was 3 dangling hoses, and the black plastic box that had been there was now destroyed and all over the ground
It attaches to the end of the evap canister and is white towards the rear end if all you see is the hoses and elec conection you need the vaccum pump. Make sure you put the pump on right hose connection goes at the bottom or it will not work right youcan put it in 4 diff ways.
Also, I don't see the pump on the parts page for the vapor canister. listed parts are
HOSE, Canister to Natural Vacuum Leak Detection
BOLT, Hex Flange Head
BRACKET, Vapor Canister
HOSE, Rollover Valve
DETECTOR, Evaporative System Integrity Module
CANISTER, Vapor
CANISTER, Vapor
Wasn't listed when I looked online either. Got everythin from the dealership. Cost the same as ordering online with shipping. Don't forget the gasket for the pump. By the way where are you located?
im out of boston. yeah I guess I'll swing by the dealer at some point. service manager works the same hours i do, so it makes it impossible to stop in the get parts
I know what you mean. I had to sneak out and get my parts during lunch. Let me know if you have and more questions and recommend getting evap arrmor protection.
I'll probably pester you for install instructions; do you know if there is a write up anywhere? and yeah, I guess while it's off I should move it
