Evap Can Skid Plate Mod
I wanted to show my skid plate and see what all of you think of it. I did not want to relocate it because of what I've heard on the warrenty. So instead of wasting money on buying one (cause later I will relocate it) I just decided to build one. I have zero in dollars in it, just the time in buiding it. I started with a scrape piece of 10 inch c channel and it went from there. The left line I already made bigger as you can see it was touching the line, so it is fixed. I'm just getting ready for the April 8th Moab run. Next, I think I'm going to do the oil pan and the front of the trans pan (the rear is covered already). Thanks for checking it out.
Used the stock mounting bolts to hold it.
45 the front and rolled the corners. Used 3/16 c channel and this just lowered the ground clearance for a total of
3/8 of a inch.
Has plently of drive shaft clearance. Cut 1 inch drain holes so mud and rocks can be washed out.
45 the back and rolled the corners, notched for the lines, uses rear mounting bolt. Painted semi gloss black.
3/8 of a inch.
