ESP problems with lift??????
Old 11-16-2006, 07:44 PM
XTREMEJK's Avatar
Default ESP problems with lift??????
I have a 4" Skyjacker lift with 35's, has anyone else found that the ESP activates on sharp turns????? I'm not sure if its the soft springs or the added tire size. Just wondering if anyone else has experienced this also.
Old 11-16-2006, 11:57 PM
JK-Forum Founder
wayoflife's Avatar
Very interesting but no, I have not heard of that one yet. Is it safe to assume that is the only time you get the ESP to come on and did you make sure to straighten your steering wheel after lifting it?
Old 11-17-2006, 04:23 AM
Quebec4x4's Avatar
that happen also on our's JK with the 2" spacer kit.
Old 11-17-2006, 06:09 AM
GoAnyWhere's Avatar
Does that kit come with a pitman arm? I spoke with one guy at SEMA that said that the position sensor is that sensitive in the steering box. Might try adding a pitman arm if it does not come with one.
-J
Old 11-17-2006, 07:01 AM
XTREMEJK's Avatar
No I dont have a drop pitman arm , but I did center the wheel. I''m not sure if a drop pitman would make a difference. I sure does look good though
Old 11-17-2006, 07:09 AM
SpudRacer's Avatar
Default Pics!!!!!!!!!!!!!
Tom
Bryson City, NC
Old 11-17-2006, 04:37 PM
dhoffroad's Avatar
yea how about some pics of your JK.....
Old 11-17-2006, 04:40 PM
IDiggs9's Avatar
I had that happen to me on my unlimited with a 2" bb . However it was an easy fix for me. I just had to adjust the steering wheel back to zero position . After a couple of tries , the ESP/BAS light goes out , the ESP does not engage any more and everything is like new again. oh, I did take it to the dealer to get the alignment checked out. Shop teck says everything is winhin spec.
Old 11-17-2006, 07:15 PM
XTREMEJK's Avatar
I had mine aligned but it still does it. I'm working on pics, my camera is on the fritz!!!!!
Old 11-17-2006, 11:49 PM
daddyo's Avatar
So, how do you re-center the wheel?
Andrew
Quick Reply: ESP problems with lift??????
