ESP indicator light
ESP indicator light
After the install of my lift and tires, I put the ESP function in the full off mode per the instructions in the book. But the indicator light is still on in the dash..
Is there any way to get this stupid light to trun off ??
Thanks...
Thanks...
What the Jeep Service Bulletin says:
While the Permanent ESP Disable feature is turned on, the vehicle will display the
following:
a. The ESP telltale in the instrument cluster will be illuminated.
b. The vehicle odometer will display a “ESP OFF” message.
So the answer is no the light will stay if you use the permanent ESP disable feature.
following:
