ESP engaging after lift and 35's
2007 2-door. I installed a 3" lift and 35x12.50-20 on 20x12 wheels. Now everything I go into a mild curve the ESP engages. Any cause or doc for this?
Did you make sure your steering is adjusted and straight? A simple check if you don't have a programmer to tell you if you are off center is to see if the JEEP logo on the steering wheel is straight when you are driving straight down the road. If the steering is off center the ESP will kick on when going into simple turns until it is adjusted. Adjustment is done at the drag link bar by unscrewing the 2 bolts that hold it in place and turning it a 1/4 inch at a time until your steering wheel is straight. Re-tighten when done and check it as it may require a couple of adjustments until it is right. There are write ups on this but I assure you it is a simple adjustment.
Former Vendor
Do as suggested re the steering wheel centering, but before you do be sure the axles are centered under the frame. Once the axles are dead centered, then adjust your steering wheel.
