Esp/bas
Esp/bas
Yeah, I have read the post about this. Just finished installing my 4" lift on my 2 door Rubi. Took it for a test drive and this light came on. I centered my steering wheel to what looks dead on perfect. I am still running the stock wheels and tires for now. Any ideas what to do? I need to get this thing completed.
Took the Jeep for about 1400 test drives and made about 1400 adjustments to the drag link knuckle and now I'm not getting the esp/bas light.
Here's a couple of after pics.
The steering wheel wasnt exactly centered. I had to drive a good bit to find a straight section of highway and found it slightly, and I mean slightly off to the right. I took it back home, adjusted it, and went back out to the same section of road and I had adjusted too far. Anyway after several attempts, I got it right.
Evidently, this adjustment has to be perfect!
Question? My ESP/BAS light is not on every time, only once in a while.
Is that the same with you guy's?
Then installing my Centerlink and Draglink I found that if I turned on the ignition and the wheel was not centered the light would come on. Even if I immediately centered the steering wheel it would remain on for between 1 and 3 days. I took the bars on and off several times because of manufacturing issues.....anyway if you have the wheel centered and all the bolts tight I would just give it a few days and it should go off. If not just stop by the dealership and hope they don't charge you.
So you guy's are basically saying that because the steering wheel is off center, my ESP BAS light has come on.
I put my lift on in February and in April right after the first wheeling trip on my way home the ESP BAS light came on. I never straightened my steering wheel after my installed my lift. It never bothered me.
I will fix this this week, and see what happens.
