ESP and ABS light on
My jeeps ESP & ABS light comes on when the car is cold but then turns off after driving for like 15 mins. Could it be my tire pressure is low?
![FJOTM Winner](https://i.ibb.co/FgFLpFN/Untitled-1.jpg)
![](https://www.jk-forum.com/forums/images/ranks/veteran_air_force.png)
It's those 20" wheels and 35s you got. No, I'm just razzing you. 14Sport is probably correct. There's a lot of wheel movement on the front, and especially when you have a lift and have to reposition those wires. That movement is notorious for tangling up the ABS sensor wiring. Inspect the wiring to see if there's any damage--it should be pretty obvious. Could be the sensor itself, but you'll need a code reader that actually reads ABS systems to figure that out for sure--most code readers don't read ABS (or SRS). Finally, I've seen the unit bearings get contaminated by mud and muck. Going by your userID and Florida location, perhaps you've played in a mud a few times? Anyway, you can inspect the unit bearing for unusual wear (like checking a wheel bearing), and for contamination by pulling the ABS sensor and looking in the hole. There should be grease in there, but not dirt, etc. Good luck!
One more possible, but unlikely, thing.I had this happen to me and it ended up being a crooked steering wheel. It would come and go until I decided to straighten it out.
