esp and 3 inch lift
esp and 3 inch lift
installed 3 inch suspension lift truck sit level goes down the road perfectly straight doesnt pull at all. Braking is also fine truck rides great.However esp keeps coming on in turns even when I have esp already off, light is on constanly but is it really off ? Have auto trans 410 ,dana 44 rear. Should i have computer flashed for bigger tires but was told that will only get speedometer a little more accurate.Will not change shifting or anything else.Is there a way to turn esp off comepletly with out pulling fuse ? I have read everyone seems to have problem like this after lift but cant find thread. Any fixes or update yet.
Thanks in advance great forum have learned a lot about the jk here. Oh I did install 200 psi gas shocks also so truck doesnt sway at all and also changed steering stablelizer shock for a better one.
Is your steering wheel centered properly?
When i installed my 2.5" the sterring wheel was a little off at first and would set off the esp. Adjusted the trackbar to properly center the steering wheel and the problem went away.
JK-Forum Founder
Hey Midblues, a few questions:
1. Are you sure that your steering wheel is perfectly centered?
2. How much psi are you running in your tires?
3. Did your kit come with adjustable control arms and if so, what do you have your caster set at?
