engine troubles, not sure if normal
My 3.8 sounds like a sewing machine. The ticking noise comes from around the injectors. I have been told that the 3.8 has noisy injectors. I have been having my JK for over 2 years and the noise has not gotten better or worst. Scared of what they may find if I take it in to be looked at. I have right around 63k miles on my 2007.
I really can't explain it better than what i did, I don't know much about engines and what i would really like to hear what a normal jk 3.8 sounds like to see if mine is the same. as far as the rattle under load i don't know where else to look or what to tell the dealer. I have gone under the jeep and banged around with a rubber mailet and couldn't really replicate anything
I ran mine 93K miles. Changed only because I was installing dual-battery tray, so it was convenient. No difference in vehicle performance/MPG before and after. Plug gap is a starting place for optimal performance. Plugs are fine as gap widens. They are designed that way. Are you sure 50 thousandths gap is correct? Would double-check that.
Also could the "rattle" be engine knock? its more of like gravel in the engine sound. I don't know what engine knock exactly sounds like though.
