Engine Cut out at high RPM
Old 03-13-2013 | 03:32 PM
  #21
ronjenx's Avatar
Until someone comes up with some tech data explaining how the JK limiter works, we are all guessing.
My guess is it controls the rpm limit through all the same programming that would come into play if you simply backed off the gas pedal.
Nothing gets shut off.
When I have tested WOT shifting, the engine reaches an rpm limit and just doesn't go any higher. It doesn't turn off and back on, sputter, or do anything other than act like I was controlling the rpm with my foot.
Old 03-13-2013 | 03:49 PM
  #22
AtlJeepsTer's Avatar
I Agree with that. It would be so easy to do it with software because even the gas pedal can be controlled and not even have to move a inch...lol...but look around the web, there seems to be this itch for a lot of guys removing the limiters....lol...
Old 03-13-2013 | 03:55 PM
  #23
Check this out.....controlling and changing the limiter in the wrangler with this unit:
http://www.bullydog.com/documents/Sp...fo%20sheet.pdf
Old 03-13-2013 | 05:36 PM
  #24
otservice's Avatar
Originally Posted by AtlJeepsTer
Here's a better one showing how it Limits the Fuel, Not Cut the Fuel. If you meant Limit the fuel in saying cut the fuel then Mistake is all cool. But we all know that the fuel is not Cut Off
governor - YouTube
Lol funny guy you know one post was enough It doesn't actually stop fuel from going to the engine or kill the engine. Cut as in restrict/intermittent/limit fuel supply. On my previous vehicles you can hear and tell when the limiter would kick in and "restrict" the amount of fuel to slow the vehicle down. It obviously doesn't cut off all fuel supply to the engine, although if it did cut off the fuel supply going into the engine there would still be combustion for that Milli-second it happened. It didn't stop the fuel going to the engine for more than a fraction of a second, so you technically don't lose any power to any electronics or mechanical parts to the vehicle.
Like we've established we don't actually know what's happened here except for the fact it is either fuel system/emissions (they are connected) related or computer related. Those are the most common problems associated with those vehicle systems. Next time I'll choose my wording more carefully
I also have that Bullydog programmer, but it's been sitting at my desk the last 6 months lol Should really get to putting it in the JK one of these days
Old 03-14-2013 | 07:38 AM
  #25
J270's Avatar
It would be my thought that the "cutting out" of the engine was actually the programmed "controlled decent" of the engines rpm's. I've experienced this at speed and I can attest to it being the feeling of a total cutout, high pucker factor was attained.
At the time of incident, were there any dash codes that were put off? if there was, its a script failure issues and your ECU and TIPM needs to be reflashed. If the issues was caused at a lower rpm that should be, you need to reprogram.
The JK has 62 computer control points, which does include a MAF sensor, even on the 3.8. These control points, monitor and manipulate everything, in one way or another. The monitoring of these points gives some 240000 code points. These combined in 48,263 scripts which work together in order to achieve the good, bad and indifferent operations that make the JK come alive. The derivative of all the "crunching" is some 800 possible "trouble" codes.
The simple explanation is that very few control/monitor systems on the JK are mechanical in nature. The JK basically works off of FM. Something happens, it goes to the computer where FM is created, a resulting action takes place. That can be a change in control setting or the output of a code for something that is beyond the systems FM capability.
Old 03-14-2013 | 09:05 AM
  #26
ronjenx's Avatar
The op's problem happened at wot during acceleration. "Controlled decent", even if his '07 JK had it, wouldn't have come into play.
Regarding the MAF sensor you mentioned, you will have to point it out to me before I'll be convinced the JK 3.8 has one.
Old 03-14-2013 | 09:17 AM
  #27
This guy had a problem with his Limiter hitting a 4000 instead of the 5500, here is what they found wrong:
(yea it was the Map Sebsor vacuum line it was cracked i replaced it and it runs like brand new thanks for the input everyone .)
Old 03-14-2013 | 09:19 AM
  #28
Ncb's Avatar
Ncb
I thought rev limiters were ignition controlled alternating ignition on/off when activated at a set RPM.
Old 03-14-2013 | 09:23 AM
  #29
Would it be Danderous if not Death of , the Ignition shutting down the power steering, power brakes, locked steering wheel and all the safety Modules wouldn't work.....
Old 03-14-2013 | 09:27 AM
  #30
You may be thinking of the AfterMarket units, because getting to OEM one is,,,
[h=1]MSD Ignition Offroad Rev Limiter for MSD6470 (Universal Application)[/h]
This Rev Control plugs directly into the 6-Offroad Ignition Control. It allows you to set an rpm limit that will save your engine from overrev damage in the event of driveline failure, a slick spot on the trail or missed shifts. The rpm limit is adjustable with special Weathertight RPM Modules and is supplied with 4,000, 6,000 and 8,000 rpm modules.
NOTE: Must be used with the MSD 6-Offroad Ignition
