Engine coolant or Hydraulic steering leak?
It feels more like a watered down oil and it has no smell.
Yeah thats gon be tranny fluid bud...no worries the dealer should fix it for you...i even believe there was a tsb with a replacement line that is supposed to be better than the original. Just make sure you got enough tranny fluid to make it to the dealer.
I should have enough to get to the dealer, thank you for helping me out.
Hope it all goes well. i seem to be having a similar leak myself over the last few weeks just not nearly as bad. Not to hijack the thread here or anything, but I too thought this was engine coolant since the coolant reservoir was a bit low (still above minimum level but close to it). What do you guys think. It's coming from the two hoses that run right along one another from the radiator back into what looks like the tranny so I'd imagine it must be tranny fluid, but you tell me. It's certainly red in color.
![Click image for larger version
ID: 455145](https://www.jk-forum.com/forums/attachment.php?attachmentid=455145&thumb=1&d=1513717967)
ID: 455147](https://www.jk-forum.com/forums/attachment.php?attachmentid=455147&thumb=1&d=1513717967)
2 hoses coming out of radiator and heading back to what looks like underside of tranny
ID: 455148](https://www.jk-forum.com/forums/attachment.php?attachmentid=455148&thumb=1&d=1513717967)
View from the top (2 hoses just below the engine coolant reservoir)
ID: 455149](https://www.jk-forum.com/forums/attachment.php?attachmentid=455149&thumb=1&d=1513717967)
Here is my engine coolant reservoir/level:
ID: 455150](https://www.jk-forum.com/forums/attachment.php?attachmentid=455150&thumb=1&d=1513717967)
js632 what do you think, is this what you had?
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=455145"/>
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=455147"/>
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=455148"/>
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=455149"/>
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=455150"/>
That said, that does look like ATF. The 2012 already has a transmission cooler, no need to add a new one. That said I wouldnt be surprised if it was a bad line. Check you transmission and power steering levels. If one is down, there is your problem.
ATF4 is what is used for both the transmission (if auto) and the power steering. It definitly has a distinct smell....
[QUOTE=JK BRO;3545693]Hope it all goes well. i seem to be having a similar leak myself over the last few weeks just not nearly as bad. Not to hijack the thread here or anything, but I too thought this was engine coolant since the coolant reservoir was a bit low (still above minimum level but close to it). What do you guys think. It's coming from the two hoses that run right along one another from the radiator back into what looks like the tranny so I'd imagine it must be tranny fluid, but you tell me. It's certainly red in color.
Attachment 455145
Your first pic looks like my 2010 looked. The lines leaking at the rubber to hard line joint should be replaced under the TSB. Ask the dealer about the TSB first.
Attachment 455145
