Engine Change
Engine Change
If I were to change to a new engine or put a new engine in. Is there a better option than the 3.8(2011 Rubi)? Would anything work with the transmission? Sorry don't know much about this
There are a plethora of options better than the 3.8. It' comes down to how much you want to spend. I keep eyeballing an LS swap with an 8 speed GM tranny. The $20K price tag I keep ending up with makes it a tough sell for a play vehicle.
almost (03-05-2020)
The beauty of the 3.8 is that it's dirt cheap to replace, other than that it doesn't have much going for it. Everything else LS or HEMI is a serious investment. If you just want an all around better driver the cheapest routes would be to replace the 3.8 and re-gear for a little more oomph, or sell it and find a 2012+ with a 3.6. My jeep is basically stock and I'm thinking of re-gearing to 4.56s.
Jordy is right on for the price of a conversion. If you do the wrenching yourself you might get an engine/tranny around $14-15k using a kit such as Motech for a Chev or RPM for a Mopar system. If you get a new V6 3.8 then I suggest you at least add a more torquey camshaft in before you install. Then tune accordingly by accessing the program. Moving the torque band down 500-800RPM makes a huge difference.
JMHO of course, but after watching some of my fellow club members hassle with LS & Hemi conversion issues I'm settled on simply replacing my 3.8L with a fresh one when that day comes. I run 37s with 5.38 gears and get reasonable highway performance, if fairly miserable fuel mileage (14mpg). The engine has 80k on it now and since new has been rather noisy, uses 1/2 qt of oil in 3,000 miles consistently. Mine technically has the Lifetme Powertrain Warranty, so if the 3.8L goes south I could probably find a dealer that will honor the warranty. However, accepting the fact the rig is fairly well modified, I'm resigned to paying for everything myself. I figure my mates & I can swap out the 3.8L in a day. I can probably find a deal on a long block and be rocking fairly inexpensively, all things considered.
A 1/2 quart every 3K miles is pretty damn good. Mine goes through a quart every 3K and I still consider that pretty good with 204K miles on the motor. FCA won't consider it an issue until it burns more than 1 quart every 1K miles.
