electric supercharger???
Never heard of anything like this. Snake oil? Or is there something to this?
http://www.force-flow.com/info_x4brushless.aspx
Last edited by Robar; 08-15-2008 at 02:53 PM. Reason: PLEASE DO NOT POST DIRECT NON SPONSOR LINKS
right up there with the As Seen On TV - Tornado ...snake oil
http://video.google.com/videoplay?do...43475142&hl=en
It would be nice to find someone that has first hand experience with such a thing.
He should have used pitot tubes to get fpm then convert it over to cfm.I could see a possible problem if the pressure in the cylinders were to get to high. Normal supercharged engines run a low compression ratio to keep the pressure down and not to mention better head gaskets..Bottom line I personally would not use it with out better equipment. MY
Agreed, be nice on a riding lawnmower . For the application he was using it for on a dyno would be the only real proof.
ok 1st take the wifes electric hair dryer,then carefully apply the duct tape to the hose you swiped off the vacuum,modify intake airtube as shown on attached cocktail napkin,hook up the 12v/110 inverter ,shazaam now your makin boost
it won't work. Superchargers are a complete system. RIPP will tell you. Do you think they just slap um on and go? All you will be doing is blowing more air into the engine. If anything, you only lean it out enough to throw the check engine light. It's your Jeep and if you wanna do stupid stuff to it, knock yourself out.
