ECM Programmers
ECM Programmers
Does anyone make such an animal for the JK's? I come from the Diesel Pickup world, and I modded the crap out of my duramax, one mod was using an ECM Programmer which not only was able to change the fuel delivery to get silly power increases, but it also scanned and cleared diagnostic trouble codes, reprogrammed for larger tires so your speedometer and ABS worked, would allow you to change the rear axle ratio for axle swaps, etc.. They were very useful and relatively inexpensive. I see a lot of folks putting larger tires and lifts on, which I wish to do, and I was wondering what you all were doing about the problems larger tires pose with the speedo and ABS.
Thanks,
Mike
Thanks,
Mike
Guest
Posts: n/a
Calibrate Speedometer
When I had an F250 Powerstroke Diesel, a Ford enthusiasts forum posted the instructions for re-setting ABS functions, if you changed Wheels & Tire sizes. I took the instructions to the dealer, and they plugged the computer in, and 4 minutes later, everything was set correctly. Can the dealer not reset the functions for us?
