E3 Spark Plugs with rippmods SC
hi guys, ive been hearing good things, about the E3 sparkplugs, and i have about 20,000kms on my Supercharger, the reason i want to order is that im ordering some parts from summitracing, and thought id add these plugs to my list, my question is that i know that the SC requires colder plugs, so would the E3 plugs cause permature detonation? or ping in timing?
Thanks.........the reason I ask is because some guys have reported that the OEM wires went to shit in as little as 30k. I also want to know if a good wire upgrade is worth the money in performance? I notice they ain't cheap... lol
Sponsoring Manufacturer
The NGK Iridium's are $11-15 each and what we consider the best overall plug, in both material and temp. The only thing we would replace it with is either a fresh set or iridium's or a NGK V Power with a copper core. These are standard plugs with our Mitsubishi line of superchargers, they work well, but have to be changed once a year. We optioned out the iridium because they will last longer. If you consider that you've relied on us for power, we wanted to make sure we didn't over look any part that could cause an issue when your out in the middle of nowhere
RIPPTECH
