E-locker vs ARB air locker.
I know Arb has been tried and true. Im wondering how the the e-lockers have been holding up? I have had ARB's for 12 years and have enjoyed them very much, but it would be nice not to have to listen to the compressor all the time. Whats the word?
So far so good on the e-locker. My ARB was great and never gave me any problems, even in deep water on days where the temps were 20 below zero... I was told by some that aRB's would do poorly if there was a lot of condensation in the air tubes... never happened.
So far no problems... with the e-locker, but maybe someone will chime on on it who can tell you different
I've heard plenty of complaints about the e-lockers, but I've heard plenty about the ARB too. That tells me you'd probably be fine either way.
One thing you might want to think about is that with the ARB it's probably going to be your compressor or an air leak that is a problem. With the e-locker its going to be the sensor inside or some of the electrics.
Personally, I like the e-locker if for no other reason than personal preference.
David are you talking about the Eaton E locker or some other locker? As far as I know, the Eaton E-locker is not a limited slip. Perhaps you are referring to Auburn locker?
ww w.eaton.com/EatonCom/ProductsServices/PerformanceProducts/Products/Differentials/Elocker/index.htm
I installed one of these in my Ford truck and it is solid. Never had a problem with it in 3 years of use.
If we are discussing the eaton E-locker I have been told directly from eaton that they are made for OE applications and not intended for bigger tires.
David
My OEM Rubi e-lockers have held up well on the trail in keeping 40" tires gripping. My only complaint is the dash button which sometimes has a mind of its own and won't shut them off right away.
David
