e-Locker lights not on...HELP
Old 05-09-2012 | 10:34 AM
JKBobAZ's Avatar
Default e-Locker lights not on...HELP
I have done the "Override" mod so that I can lock the factory e-lockers with out going into 4-lo
What has happened is that the lights on the dash are not coming on the dashboard even if I push the factory button or my mod'ed one.
I am running Aero-Force gauges and a DiabloSport tuner. I know the Diablo allows you to turn the sway bar lights on and off but see no set up for the locker.
I am sure it is something I have done!!!! any ideas????
FYI the lockers are engaging even though the lights are not on!!!
Old 05-09-2012 | 12:04 PM
ronjenx's Avatar
There are several ways to do this mod. Which method did you use?
Old 05-09-2012 | 02:15 PM
JKBobAZ's Avatar
https://www.jk-forum.com/forums/jk-w...ication-88085/
I grounded the 2 relay's next to the battery box.
Old 05-09-2012 | 02:26 PM
ronjenx's Avatar
Is this on one...or both lockers?
When did you start seeing the light not coming on? Was it ever working as it's supposed to after the mod?
Old 05-10-2012 | 08:21 AM
JKBobAZ's Avatar
The lights worked for months (both when the added switches were engaged and when the OEM system was engaged)
I think it has somting to do with the AeroForce or the Diablo but I cannot find any settings for the elockers only for the sway bar discos??
Old 05-10-2012 | 09:57 AM
grandpa jeep's Avatar
This is why I don't mod computer sh!t. It seems like it never works out
