Dynomax 17263 OR Dynomax 17230???
What is the difference is between the:
Dynomax Performance 17263-Walker Ultra Flo SS Muffler $73.95 (JK application)
and
Dynomax Performance 17230-Dynomax Ultra Flo Welded Muffler $98.95. (High HP)
Thanks
and
Thanks
So P/N 17230 is a fully welded muffler. It is a round style that is 21" over all 2.5" In/Out
The P/N 17263 is a "spun" style muffler. It is a round that is 20" over all 2.5" In/Out.
This is the muffler we use in our "rock crawler" and our Evolution Competition System.
Hope that helps!
Hope that helps!
![Thumb](https://www.jk-forum.com/forums/images/smilies/thumb.gif)
Performance both are comparable.
Similar flow.
A lot of the muscle//hot rod crowd use the fully welded style.
The P/N 17263 is a perfect fit for a JK.
So if i buy just this muffler pn 17263, this is compatible with the rest of the stock exhaust and is a direct replacement for the stock muffler? Nothing else needed? Thanks!
Our "rock crawler" system
Dynomax® Performance Exhaust | Exhaust Systems | 2011-2007 JEEP Wrangler Unlimited (4 Door) w/3.8L - high clearance off-road "Rockcrawler" design: Single - 2.5" system. 3" tip. Ultra Flo Polished Muffler
or the Evolution Competition System
Dynomax® Performance Exhaust | 2011-2007 JEEP Wrangler 2/4 DR 3.8L V6<br /> EVOLUTION COMPETITION SYSTEM - FOR OFF-ROAD USE ONLY: Single - 2.5" Cat-Back System, 2.5" Spout, Ultra Flo Polished Muffler
I did some research on here and found a few examples of people inserting this muffler under the driver side before the axle. Then went outside and looked at my Jeep. Problem is, for my 2 door stock exhaust, there is no section of pipe straight for 20 inches that i could remove and insert this muffler. Anyone done this in a 2 door? Thanks
If you want check out our Facebook page, if you are on there. There is a whole JK album and a lot of it is the system that uses this muffler.
This will give you an idea.
https://www.facebook.com/photo.php?f...type=3&theater
