Dynatrac on order
As leaning towards the Core 44 but with true trac was back ordered until summer. Decided to go with Dynatrac instead only $400 more. Will have chromoly shafts, synergy ball joints, 4.56 and true trac.
Unlimited means its set up for higher lifts.
You want to make sure its a HD version.
This means thicker tubes.
edit:
from the FAQ
Dynatrac ProRock 44 Standard Axle Tube 3.0" OD x 0.3125" = 1.49
Dynatrac ProRock 44 Extreme Duty Axle Tube 3.0" OD x 0.5" = 2.22
You want to make sure you get the .5" thick tubes.
edit:
from the FAQ
![FJOTM Winner](https://i.ibb.co/FgFLpFN/Untitled-1.jpg)
Their standard tubes are still a decent upgrade from the stock housings, but if you are going for strength, may as well bump up to the thicker ones. It's only another 14lbs... ![Big Grin](https://www.jk-forum.com/forums/images/smilies/biggrin.png)
I got mine 6 years ago, before all these other mfg's got in the mix. It's been a great axle.
I am soon to be making a similar purchase, a 44 of some form in a JK. My question would be:
What other money needs spent to go along with the installation? I have a 2" Mopar (Teraflex?) Stage 2 suspension with adjustable track bar. Should all of my front end parts swap over just fine, or will I be looking at replacing basically new parts (Under 10K miles on my JK) to fit with an aftermarket complete front axle?
I am torn between the G2 Core 44, Teraflex Tera44, Curri RockJock 44 and Dynatrack Pro-Rock 44.
I also like the G2 Core 44 the most (based on looks)
The Teraflex is really Purdy as well, second choice!
The Dynatrack would be third choice and Curri last.
I don't think any of the JK 44 options are bad choices, all read like they are great structural upgrades over my D30, so being that they all pretty much are golden over my bent junk, I'm at the point that I am basing on price primarily and then visual appeal.
