dynatrac ball joints
so all 4 of by ball joints have went to shit, i was wondering if the dynatrac ball jonts are wroth the $500 or should i go with the factory for hundred! thanks guys
oh and thanks wayoflife. i wish i would have checked those 2 months ago.
warrenty
i went to the dealer and they laughed at me. said i had to many mods. i talked to the the manger, and he said he is going to try to have it warranted (since i am military) and will let me know fri. it would be bad ass if they do. i only have 20,000 miles on it
The ball joints on my XJ never wore out the 14 years/186,00 miles I owned it.
JK-Forum Founder
regarding the dynatrac ball joints, they are expensive but should be the last set you will ever need to buy. as mentioned, they aren't available just yet but should be very soon. for now, i just installed a set of crown replacement ball joints.
JK-Forum Founder
bad ball joints can make your front end feel loose and can instigate death wobble. you can tell if they are bad if you see "radial movement" in them. this is side to side movement and there should be none. a little "axial movment" is normal and that is an up and down movement.
to check for this, you can jack up your front wheel, grab it at the 12 and 6 position and push it opposite each other in and out. here is a video of what you should NOT be seeing...
http://www.facebook.com/video/video.php?v=152282577846
this ball joint is really bad and typically, movement is measured using a dial indicator.
The video in WOL's post is a good one.
Here are the numbers from the factory service manual:
Radial (side-to-side) movement in the upper ball joint should not exceed 0.060" (1.5mm).
Axial (up and down) movement in the lower ball joint should not exceed 0.050" (1.25mm).
