DW after 4" rancho install
I just installed my first lift kit yesterday, and now if I hit a bump at 10-50 mph the front end shakes so violently I have to pull off the road and come to a full stop. Any ideas on what I could do? It was the 4" rancho sport suspension with rs9000xl shocks on a 2008 JKU, thanks for all the help.
There are a couple of good writes up here. Do a search for Planman. He explained it the best.
Sorry and good luck.
Assuming your kit came with adjustable trackbars. Id so, simply torque your trackbar bolts to 125 lbs. The trackbar seems to be the culprit in most cases. If this solves it, go get some 9/16" grade 8 fine thread bolts and prevailing torque nuts and replace the 14mm OEM bolts.
