? on duster and safari top
Do u need to buy header and tail gate channels if u already have soft top. I'm looking at safari top and a duster but it says u need thos other pieces too.? 2011 4dr rubi.
You need to decide what brand of top you want to buy before you can get a correct answer to this question because there are differences between Mopar and Bestop and whomever. Also, there are issues with the various safari tops fitting the newer JKs--changes in the header design and the way the tops attach to the door frames. While I know quite a bit about the older design, I'm at a loss for the 2011s except to advise that you first research the changes in design to avoid compatibility problems.
thanks.. yea I was looking at best top. For top ,duster and jammer. I think we might just go with mopar top . There was a guy out here that did a wrap hammer from a 2 Dr on his4 Dr . Did that change to? Do u no?
On the best top package quadtrac the safari, windjammer , and deck cover it says it comes with the windshield channel. My question is mine came hard top only so can I buy just the tailgate piece that it requires? Mine is a 07 4door.
thanks just ordered it all from them should be here in a few. hope it looks as good as i hope. still cheaper than a soft top!
Yes, I believe that the changes were on the door frames and at the header bar. I think that the rear end pieces are unchanged (actually, it would seem now that I know since you've just confirmed that!).
