duratracs and 18" stock rims
Old 11-10-2010, 07:39 PM
PG-JKU's Avatar
Running the 275/65R18s on stock rims with no spacers. Slight rub on swaybar at full lock. Diameter just slightly bigger than stock. Love them!
Old 11-10-2010, 07:45 PM
jk-willys's Avatar
I'm going to add a 3.5" lift to my jeep and I'm wanting to go up to a 34-35in tire
Old 11-10-2010, 07:47 PM
Enzo's Avatar
Originally Posted by jk-willys
maybe you can recommend something. my stock tires are 255/70R18's i have stock moabs for the 08 jeep unlimited sahara
You got stock "Gladiators" as 18" rims, the 17" are Moabs , you should be able to run 285s max without rubbing on the stock rims, with no spacers
Old 11-10-2010, 07:48 PM
jk-willys's Avatar
what type of tire are you running?
Old 11-10-2010, 07:49 PM
jk-willys's Avatar
that is exactly what i was looking for man thanks
Old 11-10-2010, 07:53 PM
PG-JKU's Avatar
I am running the Duratracs. You will rub with the 285's. I rub with 275s but only at full lock.
Old 11-10-2010, 08:00 PM
jk-willys's Avatar
i think thats what im going to go with as well but im hoping that the 3.5 lift and 1.25bs helps with rubbing
Old 11-10-2010, 08:10 PM
PG-JKU's Avatar
You won't need a 3.5 lift. 2.5" lift will let you run 35s with less problems.
Also I hope you mean 1.5" spacers, not backspacing.
Be aware that lifting does not necessarily solve rubbing issues. Swaybar link geometry on a lifted rig will cause the rears to rub on stock rims without spacers, while you might get away with running the same rims and tires unlifted with less problems.
Old 11-10-2010, 08:12 PM
jk-willys's Avatar
lol as goes the rest of my posts. i meant spacers an not bs. In my defense i just learned what back spacing was just before i posted that last comment
Old 11-10-2010, 09:04 PM
Enzo's Avatar
tirerack And discounttiredirect are alot of help with tire selection and spects
Quick Reply: duratracs and 18" stock rims
