Duratrac run small but this is crazy
Old 08-06-2013, 12:44 PM
Forum Tech Advisor
planman's Avatar
MTRs run taller.
KM2s run shorter.
I'm more concerned about tire performance than whether they measure 0.5" taller or shorter than others.
I run 35x12.50R17 Toyo MTs on my crew cab, 1 ton, Ram diesel truck, pulling 14k+ lbs on a gooseneck trailer.
I would never run them on a rig that weighs less than 6000 lbs. They are 125Q, load range E tires with a max load 3640 lbs at 65 psi. They were designed specifically for heavy loads.
Old 08-06-2013, 06:16 PM
loserhead4236's Avatar
^ I have these tires on my 2 door and run them at 21 psi on the road because of this reason.
Old 08-06-2013, 08:45 PM
BKGM Jeepers's Avatar
My MT/Rs run pretty true to size.
Since a couple of tires run small, why not buy based on measurement rather than size on the label?
Old 08-06-2013, 10:42 PM
GunDude's Avatar
Yep, 33.5" at 35psi. I lowed psi to 30psi for better on road handling. The Duratrac's do not come in a 37".
Old 08-07-2013, 01:35 AM
RedRockJeeper's Avatar
Originally Posted by stevedolce
I really love the tires--but would like something a little more true to size when these are done.
Then go with a Super Swamper branded tire. In my experience they are right at what they say they are or LARGER! They are however, very pricey!
Old 08-07-2013, 02:46 PM
JK UNLIMITED's Avatar
And you might get 15k miles out of them...great tire offroad though!
Old 08-07-2013, 03:28 PM
Challenger392's Avatar
I bought mine new same size in January and with Moto Metal wheels they measured 33.4 inches. Nowhere near 35's but I'm still very happy with them. Great tire.
Old 08-07-2013, 03:58 PM
stevedolce's Avatar
Absolutely great tire! I was too heavy on the cough syrup when I said I may look at another tire.
Old 08-08-2013, 03:48 AM
Bsimon187's Avatar
My 315/75r16 duratracs came in at 33.75 at 32psi. Rides great on road so far. Used that measurement with my pro-cal and the speedo matches my external gps.
Old 08-08-2013, 08:21 PM
Namtaru's Avatar
My 33x12.5x15 BFG TA KO's measure 31" mounted at 32psi
Quick Reply: Duratrac run small but this is crazy
