Duratrac run small but this is crazy
I'm running 315/75/16s at about 35psi. Just reassured my tires to calibrate my flashpaq and they measured a little over 33 INCHES!!!! Jeez...
I've got about 38k miles on my tires--
Can other GYDT owners post up their tire hight??
Forum Tech Advisor
Depending on wheel width and weight of your rig, most tires measure 1"-1.5" less than the labeled size when mounted and on the ground.
Most 35s are around 34.5" unmounted and around 33.5" mounted when brand new. Some are a little taller and some are a little shorter.
Duratrac 315/75/16s are reported to be 34.6" unmounted and new, but I'd bet that actual specs vary a little.
It would not be surprising that a 35 with 38k miles would measure close to 33" if the wheel was wider than 8" and he rig was on the heavy side.
My 33" DT's ran about 33 1/4" at 32psi and a little bigger when I ran them at 40psi which I had to do to get the mileage above 11mpg and they rode just fine being a load E tire that was the recommended pressure! But my 35" MTR's run about 34 1/2"
