DuraTrac 255/75R17
DuraTrac 255/75R17
Any reason why these tires are so much cheaper than other sizes smaller or even around the same +-1"? DuraTrac 255/75R17
http://www.tirerack.com/tires/tires....7WDT&tab=Specs
They are P rated tires. Most other ones are LT tires which are usually more expensive. I have these and like them a lot. They are very light compared to other tires and still capable for my use.
Also, being that it's P rated, would the softness make it so the tread wears faster? Or does that ONLY apply to the side wall?
I looked into Duratracs, as I have installed them on many different vehicles, but in that size they're a little weaker because of the 'P' rating.
I just got back from the shop with a new set of Cooper ST Maxx tires as a replacement for my 5 year old BFG Mud-Terrain tires that came on my JK.
If you're mostly on road with a little bit of trail once in awhile, then the P rating is not going to hinder you much. Less weight, better MPG etc......
If you like the trail as much as possible, you're going to want (need) a beefier tire. I went with the 255/75R17 even though my JK is lifted 2.5", it's a smoother ride and turning 35" tires would be too hard on the front end and the wallet.
Signifies its primarily used for passenger cars and minivans. The sidewall are typically weaker, where as most LT tires are a little more aggressive tread and have a heavier sidewall rating.
LT235/80R17 - $212 per
vs.
P-Rated 255/75R17 - $160 per
http://www.tirerack.com/tires/tires....=45-69212208-2
