Dupli color bed liner questions
Old 07-29-2013, 09:26 PM
Josephrobby's Avatar
Default Dupli color bed liner questions
So tomorrow I'm going to bedline my stock stubby bumper, rear bumper, and eventually the fender flares i cut (cant decide whether i should go through the hassle of taking them off or not). and i was wondering if i should sand off the texture on all of the plastic and how many coats i should do. Also, my hard top is getting pretty scratched up and figured it would be cool to have the whole thing bed lined, anyone done that? and lastly, i have polished alloy pro comp wheels i was wondering the process if there is one i would need to go through in order to bed line them as well thanks in advance.
Old 07-29-2013, 10:10 PM
nthinuf's Avatar
Haven't tried it on flares or plastic bumpers. Works great on my metal bumper, rails, and inside the fender wells. Also works great on the inside of my hard top.
Worked good on the outside of the hard top for about a year, then started noticeably fading and flaking a bit. But - spraying it was a last minute decision and I didn't prep, just a rushed scuff with a bit of sandpaper, wipe and spray. Rather than re-doing with bedliner, I might look at something a little smoother/less rough.
Old 07-29-2013, 10:12 PM
Do you think it would be any better if I prepped the hard top better or no?
Old 07-30-2013, 01:31 AM
kh202's Avatar
I recommend rustoluem over duplicolor. I've used both and like the look of the rustoluem much better. Before you commit to all that, spend $12 and get a can of Each and test on a piece of scrap metal or something
Old 07-30-2013, 01:33 PM
EsByrd's Avatar
i use raptor liner and love it. ive had my bumpers, side steps, hinges, pinch seam, my floor pan, and i wrapped it out the cargo area to were the body line is that runs from rear door to rear door for a year now with no chipping, fading, or peeling. for the price its a great product
Old 07-30-2013, 07:21 PM
I ended up doing it. Doesn't seem super strong but then again paint was very fresh. Came out great looking though. Now to do my flares. Figure taking them off is easiest, anyone know where I can get the clips for cheap,
ID:	483576   Click image for larger version
ID:	483577   Click image for larger version
ID:	483578   Click image for larger version
ID:	483579   Click image for larger version
Old 07-30-2013, 07:58 PM
nthinuf's Avatar
clipsandfasteners.com.
A20887 $8.92 box of 15
A11146 $2.97 box of 25
And if you think about it, post an update in a month or two. I'd like to see some feedback on how it holds up on the more flexible plastic flares and bumpers.
Old 07-30-2013, 08:09 PM
Will do...
Old 07-31-2013, 07:34 AM
Originally Posted by Josephrobby
Will do...
And how many of each do you need?
Old 07-31-2013, 11:30 AM
nthinuf's Avatar
How many do you plan on breaking when you remove the flares?
I am on my 3rd set of stock flares, and still haven't bothered to count how many of each type of clip is used. The flares seem to rip off fairly easily, so extra boxes aren't a bad thing.
Quick Reply: Dupli color bed liner questions
