A dumb locker question!!
Old 04-17-2011, 08:31 AM
deltaneo1's Avatar
Default A dumb locker question!!
I was getting ready to do the lockers and gears for my jeep. I was going to go to 4.10's and I know the front needs a locker on the front but dose my dana 44 rear have a locker from the factory? its not a rubi. So I wanting to know if I need lockers for my front and rear?
Old 04-17-2011, 08:33 AM
Red Stinger's Avatar
If it isn't a rubicon then no you won't have a locker in the rear. You might want to consider 4.88 gears if you plan on going with a 35 inch tire. Also you might have to change the carrier in the front.
Yeah you probably want 4.88 gears to get it back to stock.
Old 04-17-2011, 08:35 AM
deltaneo1's Avatar
I already have 35's and people told me go to 5.13's but i think that is a little high. 4.88 work out good? thanks for the help.
Old 04-17-2011, 08:36 AM
Do you have a manual or auto?
Old 04-17-2011, 08:38 AM
deltaneo1's Avatar
manual. also are Detroit lockers any good? or what kind do you guys think would work best for someone that is mild off road and on weekends or maybe 3 times a month.
Old 04-17-2011, 08:41 AM
Most people will say go ARB I think. The 5.13 vs 4.88 is kinda up in the air. If you do a lot of highway driving go 4.88. Otherwise 5.13 would be great for offroad.
Old 04-17-2011, 08:45 AM
deltaneo1's Avatar
Ok cool i think 4.88 will work then, I can only go on the trail when im not working or my wife isn't bitching. So not that often . thanks for the help.
Old 04-17-2011, 08:46 AM
Bacon's Avatar
wasn't there a rear locker option in '07? I think they're might have been. regardless, if you don't have a switch labelled "axle lock" on the dash down by the esp switch, then you don't have a factory locker.
Old 04-17-2011, 10:19 AM
nthinuf's Avatar
What is your budget for lockers?
Post 7 in this one is a good place to start
https://www.jk-forum.com/forums/show...28-best-locker
And try plugging your VIN in here. If you are in the system, it will show if you have a factory limited in the rear.
hxxp://www.compnine.com/index.php?res=1
They aren't the greatest option, but depending on your needs, it may be sufficient.
Old 04-17-2011, 01:36 PM
rexicon's Avatar
uhmm if you don't know if you have lockers do you need them
Quick Reply: A dumb locker question!!
