ds talk
ds talk
Jus noticed that I may need to change front ds an need ur advise. So I Jus got done reading some older threads an they were talking about some ds that come with adapter pieces an others coming with new yokes. What's the difference between the two an which is the better application with the least problems? Advise please.
The ones with the adapters will bolt directly onto your JK. The ones with the yokes , you will need to put these yokes in your transfer case and differentials. I was told you want to go with the yokes to avoid driveshaft vibrations. I just ordered a set of Coast shafts from Northridge.
Down in the write-ups area, there is an index at the top.
The adapters move the mounting points further out (away from the pinion and tcase outputs) which creates steeper shaft angles and more opportunity for vibes. New yokes are considered to be the better option.
I couldn't find the yoke style shafts on Coasts website. All I could find were the ones with the adapter shafts. Going off of Eddies write-up, and the picture on Norhtridge website, I'm assuming what I have coming has the yokes.
