DS Sanity Check
Help me verify my reasoning and choices..i have done my homework and I know the issues with both the front and rear driveshafts .
2011 2dr Auto Trans sport
I have recently installed a RK 2.5" Max travel and I actually got about 4" in the front and 3.5" in the back..2" bumpstop front and rear. i am expecting about .5" settling to occur..
the front is a no brainer i am going to get a custom shaft made so that i can clear the skids and transmission when flexing it out..the rear on the other hand i am thinking that i can fix the pinion angle with the RK adjustable Upper CAs..
some things you should know.. i am broke so front and rear shafts are not an option at this point.. will the Rear Uppers make enough difference for the rear to last another year? or should i just get the rear DS instead and not flex out my rig until i can get $$ saved for the front DS.
thanks in advance guys..
Choices :
1. Front DS and RK Rear ADJ Upper CAs
2. Rear DS and Swaybars stay connected until i can afford a front DS
I wheel at least once a month, usually 2xs
Choices :
JK-Forum Founder
that's a tough one. installing a new front will allow you to clear your auto tranny and skid but, being that you have a 2-door, your rear shaft is most likely going to fail sooner than later. even with a torn boot, you can make your front shaft work for you for quite some time. i personally might go with the rear shaft first but, if you don't already have them, you will need to install rear adjustable control arms so that you can set your pinion angle.
make sure i understood correctly
WOL my best option would be. (Buy me the most time to save $$)
Rear DS, Adj Rear Uppers, and leave the sway bars on until i can swing the Front DS.. ?
thanks in advance
thanks in advance
JK-Forum Founder
do you always have to give such uninformed advise? the front shaft won't spit grease before the rear. the slip shaft boot will catch and tear the first time the OP flexes his jeep and unlike you, he knows as much. being that he has a 2-door, the rear cv boots and joints will fail prematurely and, given the circumstances and the fact that he lives in FL, addressing it first would be the smarter thing to do.
![FJOTM Winner](https://i.ibb.co/FgFLpFN/Untitled-1.jpg)
That's odd, since I have read threads from guys with 2doors that lost the front shaft first. There were even a few who posted about taking advice and replacing the rear before it was damaged, then not having the money to replace the front when it went. For me, I lost the joint on the front shaft, but the boot was absolutely fine. So yes, I'll stand by my comments.
JK-Forum Founder
![naw](https://www.jk-forum.com/forums/images/smilies/icon_naw.gif)
newsflash, jeeps are rear wheel drive vehicles and having your front drive shaft fail is not as big deal as losing your rear. in case you missed it, you don't even need one for daily driving and some JK's were actually made without one. just because you read of a couple of people who decided to change out their rear drive shaft first and then later had their fronts fail doesn't mean that their rears wouldn't have failed first. and, from what i've seen with my own eyes on numerous occasions, they do fail first on a 2-door.
