Is a drop pitman needed with a Currie Currectlync Steering?
I prefer the synergy track bar bracket but others make nice ones as well. Just to note that you do not want to run a drag link flip unless you are running 3.5"+ of actual lift.
When you raise the axle side track bar and flip the drag link it will come into conflict with the frame and limit your up travel, hence the added bump stop.
They made 2 updates. I put on the 2nd generation and they are polyurethane instead if the cheap rubber from the 1st. I gt the 3rd but one look and decided not to install. Mine leak a little but no bad problem since. The Currie tie rod has been my biggest regret to date. Should have gotten a synergy.
So they sent me an email asking about my setup and said that they felt it was my lift and the fact that I didn't' have a drop pitman arm. Is this accurate? A lot of what I've researched has said this is not needed. Anyone have any thoughts on this? They are saying also, that with my caster I may be pinching the boot.. once again, seems like a load of crap. In their defense though, the drag link sure does lean forward quite a bit.. thoughts anyone?? I'm really getting sick of not getting this dialed in.
Were you talking with some guy named, David (Dave)?
A quick search here would have alerted you to the fact that there are many of us who are experiencing the exact poor quality issues that you've observed. What is really interesting is that given all the "documentation" of these issues on this site and others, Currie still has the cojones to imply that something is wrong with your setup.
It was Chris I was talking with and I'm going to pass along the forum for them to look at, see if it changes anything.
I told them I was over the repairs and they offered to take it back and refund me. Since I purchased through N4x4, I called them. After talking with them they convinced me to give it one more try and since they are opening a shop in Colorado I said ok. Going to take it in and see what they say in a few weeks.
Wondering if you guys can help me out... I need pictures of your drag link and tie rod ends. It appears my drag link is rotated too far forward, but I need some comparisons. Can anyone take a quick pictures of your ends and post for me?
Thanks,
Thanks,
