Drop pitman and Bracket safe....
Old 01-31-2009 | 06:51 AM
roguejk's Avatar
is there no need for a new drop pitman arm with the drag link flip kit?
Old 01-31-2009 | 06:55 AM
JackMac4's Avatar
Originally Posted by roguejk
so ill be ditching my skyjacker 3.5 " spring lift for rough country's 4" lift with the drop pitman arm, so i should not use the drop bracket? the yers flex kit is for 5" and above what other options do i have?
you'll have to use something - or you'll have some wicked bump steer. The bottom line is you have to get your steering geometry to be as close to factory as you can in order for the steering to feel right.
As has been mentioned there are a couple ways to do this - dropping the pitman arm or raising (flipping) the drag link, and finally lowering the trackbar.
In general, the lowered pitman arm is the easiest to install but is also the easiest to break. The drag link flip is a better option in my opinion and I can attest to how well it helps things. I've seen a lowered pitman arm on several people's JKs and it seems to work just fine though. WOL will tell you though he's gone through about 3 of them at least, and they are likely to break if you really wheel - but for a lot of people they work well and have no issues.
Either way you'll need to drop the trackbar mount down, and several lift companies provide a bracket to do this, and this should work just fine for quite awhile in most cases. Until you brace the bracket though and keep its ability to act as a lever to a minimum, you risk breaking it.
Does that clear up any questions you had?
Old 01-31-2009 | 08:08 AM
TeraFlex's Avatar
Sponsoring Manufacturer
With the TeraFlex kit, no.
Old 01-31-2009 | 08:43 AM
ScottK's Avatar
No, you need one or the other, not both.
Quick Reply: Drop pitman and Bracket safe....
