Drop pitman arms???
Old 02-04-2009 | 08:35 AM
Robar's Avatar
Originally Posted by joneszj
It seems, you use the drop pitman with a trac bar bracket...so if i have an adjustable front track bar, would this eliminate the need for a drop pitman?
No.
Originally Posted by STUPIDFACE
...or would an adjustable track bar eliminate the need for a track bar relocation bracket?
corey d
Not necessarily. With a 4" lift or more just using an adjustable track bar will bot bring you steering components in to alignment. The steering needs to be as parallel as possible to resemble the stock set up to prevent bump steer.
Old 02-04-2009 | 02:55 PM
Bluewaterrider's Avatar
Question
Originally Posted by Robar
No.
Another question:
You can either drop the track bar bracket at the frame OR raise it at the axle right? any pros or cons to the way(s) to do this?????????
Old 02-04-2009 | 03:01 PM
Robar's Avatar
I believe the frame mounted brackets have better support for the track bar. Most of the axle mounted brackets simply apply more leverage to the OEM bracket increasing the likely hood of failure.
Old 02-04-2009 | 03:24 PM
Lightbulb
Originally Posted by taters_jk
So I am waiting for my 4" teraflex with flex arms to arrive right now. What I am gathering from all of this is I should wait for the next install party and bring some extra cash incase I need to run to the store to buy a pitman arm? I don't want to have anything screw up on my suspension because I just didn't know. Shouldn't these "kits" include everything you need to raise your Jeep to what you want?
Some ( NO BRAND NAMES MENTIONED OR IMPLIED ) say that thier lifts are "complete" and include everything that is needed for a lift of the advertised height.......BUT they ASSUME you are gonna run heavy bumpers and a winch and a 35" spare so you have to re-engineer the 'COMPLETE' lift because it gives you more lift than you wanted thus resulting in greater drag link and track bar angles which equal bumpsteer and shoddy handling.
Old 02-04-2009 | 03:54 PM
TeraFlex's Avatar
Sponsoring Manufacturer
I drove my JK with just a adj TB in front for 12,000 miles. I did not have a drop pitman or the flip draglink kit then. Later I added the #1600440 flip drag link/tb drop bracket brace kit to my JK. Give me a call if you have any questions.
Old 02-04-2009 | 04:02 PM
DeepSky's Avatar
I think WOL already answered this, but can you run a drop pitman arm with an adjustable trackbar without the need for a bracket to drop the trackbar down or is it recommended to drop both the pitman arm and the trackbar at the same time?
The idea is to keep the drag link, and track bar parallel to each other, and as horizontal to the axle as possible right?
Would this bracket work well in conjunction with the Skyjacker drop pitman arm? http://www.quadratec.com/products/16191_9006.htm
Old 02-04-2009 | 05:26 PM
joneszj's Avatar
So, even though there's been an explosion of questions, here's one more...
I will soon be installing my 4" Superlift with the Adj track bar and running 35s with Rustys front lower arms and upper rears.
I drive it alot as a daily driver and really dont want issues with wobble or shakes...So, will I need the drop pitman arm and a trac bar bracket? Or will it be fine as is for a while?
Old 02-05-2009 | 03:39 PM
DeepSky's Avatar
Bump for answers :P
Old 02-08-2009 | 10:21 AM
joneszj's Avatar
bump...any answers?
Old 02-08-2009 | 01:08 PM
Gokracer1's Avatar
Well IMO i do not like drop pitman arms.. The leverage they put on the gear because they drop so much, is not a good thing to me. I have the TF drag link flip kit and prefer it WAY more.
I also have the TF HD Front TB w/ the JKS Track bar brace which also raises the TB axle mount hole a few inches higher. I have NO problem w/ bump steer or anything associated w/ that. I ran the Brace before the flip kit and did have a bump steer issue. The Drag link flip kit fixed that.
I know if you buy the TF drag link flip/TB drop kit it kills both issues in one kit
http://www.teraflex.biz/products/jk-...-flip-kit.html
This is Ctimrun's Rig w/ the TF kit installed
