driving with front driveshaft only/4 hi question
I am pretty sure that the source of my vibration is an unbalanced rear driveshaft. I have pulled the front and that is not the culprit. I have tried NUMEROUS other suggestions and have basically narrowed it down to the rear ds. I am going to put the front back on and remove the rear. I will then drive in 4 hi. My question is how fast can you drive in 4 hi? Can you drive on the freeway? How long can you drive this way without causing any damage or is this just a bad idea? Thanks!
I drove 5 hours home from catskills jeep jamboree with only my front driveshaft a couple of weeks ago. I drove upwards of 70 mph but mostly kept it to 65 mph, just take it very easy on tight turns. Dont accelerate too quickly either. Other than that, no problem. It will handle a bit quirky so be careful but I didnt have any problems doing 70mph. When u r making very tight 90 degree turns, take it very easy since it is stressful on front u joints on axles.
I will add that once I got it home, I parked it until I got new rear DS since the around town driving seemed very stressful on jeep with just front shaft.
