Driving with front driveshaft disconnected, but not removed
![FJOTM Winner](https://i.ibb.co/FgFLpFN/Untitled-1.jpg)
I have read several threads indicating that it is ok to drive with the front shaft completely removed. What I am wondering, though, is if there is an issue with unbolting just the front, and leaving the rear connected? (and securing the front, of course)
I was killing time at a local shop, bs'ing with one of the guys there. We got around to gearing, and at one point he mentioned that they sometimes do this when a customer has only one axle geared due to money concerns. He suggested wrapping tape around the front to keep 'something' from falling out, (I don't recall the actual reason) and securing it to a control arm with zip ties. Figure I'd use a ratchet strap or something a bit more sturdy than a plastic tie, but wondered if there is any downside to running this way...
Depends on the t-case. The YJ didn't have a true neutral, so the front would turn in 2wd. The TJ had a true neutral.
Honestly, I don't know about the JK, as I've never tried it... but if you disco the axle end first, it'll turn by hand if its got a neutral.
If you look at your owner's manual, it says NOT to tow the JK on a front wheel caddy. On a caddy, the front wheels/drive shaft do not turn while the rear drive shaft does. Damage could result.
If you disconnect the front drive shaft and restrict it from turning while driving, the t-case would see this the same way it would see the front wheels on a caddy. Could cause damage.
In view of what the manual says about towing on a caddy, I called SpinTech about their locking hubs, and why this would be OK, since the front wheels would not be turning the front drive shaft when unlocked.
They said the difference is, the front drive shaft is still free to rotate, thereby avoiding t-case damage.
I haven't verified whether or not the front drive shaft really NEEDS to be able to rotate, but several things point in that direction.
I would remove the drive shaft. If it were to drop down at any speed, it could be a disaster.
![Thumb](https://www.jk-forum.com/forums/images/smilies/thumb.gif)
![eek 2](https://www.jk-forum.com/forums/images/smilies/sSc_eek2.gif)
I'm regeared. I was actually thinking about some posts that mentioned a mpg increase from not having the front shaft connected and turning. An extra 1-2 mpg's on a few 1500+ mile trips might add up. Figured I'd have the back of the jeep crammed full of junk, so thought I'd get opinions on disconnecting but leaving attached.
But, sounds like making room for it in back is the better option
IMO, not regearing the front axle is a bit of a "hack", hacking a "hack" by not removing the front driveshaft completely is asking for trouble and inviting Murphy and his law into your life.
![naw](https://www.jk-forum.com/forums/images/smilies/icon_naw.gif)
hmm. i drove mine like that while i was messing with my castor adjustment and was getting vibes with the front shaft still connected. i ended up taking it off altogether though.
dude by the time u read through all these posts, u could have removed it.
if u have that much crap cramd into the back and cant fit that tiny drive shaft then u seem not to care that much about gas milage. for every 100lbs u loose a certain amount of gas milage so id be packing a little less
just remove it and avoid any damage. when that shaft spins up through the floor and breaks other parts, i betcha you will be sayin oh crap should have taken it off. im not trying to be an ass but hate to see people make mistakes and broken parts when they could have taken 10 minutes to do the job properly.
