driveshafts or regear? hmm
Old 11-22-2011, 05:38 AM
D_engel's Avatar
considering you dont do a lot of wheeling, i say do gears. Yes they are more expensive, but you benefit more from gears at this time. It will have a major improvement in your day to day driveability.
Old 11-22-2011, 05:46 AM
jpkjk's Avatar
That's what I need rite now an will eventually get my ds also.
Old 11-22-2011, 07:07 AM
Bosox5's Avatar
x10. Do the gears, unless the driveshafts are toast. My front ds boot was toast quickly and I ran it for a year that way, but keep an eye on them for sure. Don't fear the gear, my best upgrade for sure.
Old 11-22-2011, 10:06 AM
jpkjk's Avatar
So then I guess I should get a master rebuild kit so its done rite.
Old 11-22-2011, 10:32 AM
SergeantChuck's Avatar
What's another $500 after the cost of getting the gears done? Do both. Replace the DS most commonly damaged for now.
Old 11-22-2011, 11:14 AM
jpkjk's Avatar
After what I spend on gears and install it b like squeezing blood out of a turnip. Lol....
Old 11-22-2011, 06:47 PM
Mark's Avatar
Driveshaft. So your 0-60 sucks for a bit but it still goes, you lose your DS, you aint going anywhere. Now this is assuming youre about 3 inches of lift.
Old 11-22-2011, 07:00 PM
mkjeep's Avatar
He's got a 4dr, his rear stock shaft will last a long time. The front will go first, but he has time.
Gears, as others have stated should be your choice.
Old 11-22-2011, 07:06 PM
sahara4me's Avatar
I have a 4" lift on my JKU for about 4 months now and my front driveshaft boot had already split when i replaced it with my new front DS... Your rear shaft will be fine specially on a JKU... Like what has been said, gears will help your day to day driving ability and find your lost power. If you do the gears and hold off on the shafts and the front goes you can always pull it and go without till you can save up the $450-$550 for a new one and still be happy with the $ that the gear swap is saving you over time in fuel... Its pros and cons to either, its all about what will suit you best.
Old 11-23-2011, 01:32 AM
jpkjk's Avatar
One of the reasons I was pushing for a regear first rather than ds is I dont no how much xtra wear an tear I'm putting on auto from trans always searching for the rite gear an not finding it so I think the regear is my way to go for less stress on other parts of jp
Quick Reply: driveshafts or regear? hmm
