driveshaft noise?
#23
I doubt this is it since mine is a 2010 so it's s bit different but I had a grinding/grunting sound upon initial acceleration before and dealer tried everything to find it but couldn't.
During a not so routine need to change my auto sump pan, I had to take off my auto trans skid. When new pan went on I took it for a ride without the skid and noise was gone. I put the skid on and it came back. Found that the skid was making contact with part of my exhaust so I added a couple of washers under the bolts to drop the skid like 1/8" or so. Noise hasn't been back since.
I know the skid plate became a skid bar in 2011 so not sure if I'd have the same issue if I had that. Have no clue on design of new engine maybe check out skids as well.
#25
I had same problem and found by lifting up on my front bumper I found the sway bar bushing creaked and transferred the noise to what I thought was my transfer case. Took apart sway bar at frame mount, move bushing inward and lube with white lithium grease. Solved for me.
#26
Guys I had the same issue at low speeds and at take-off. It turned out to be the passenger side front lower control arm. The installer had it misaligned and it was binding at low speeds. I had to take off the rear bolt, adjust it and reinstall. Noise is gone.
#28
Second day, sound only a bit better. Well time to start finding other options. Does anyone know any place that does modified jeep work herein RI? Dealership won't touch it
