Driveshaft help
Since u already have your shaft out just bring it with u and compare it to the new one. Work the u joint on the new one and extend and compress the shaft. Everything should be smooth with little to no noise. Compare the ends of each to be sure they are the same. Check the extended and compressed lengths. They should be the same. Ask the seller why he replaced it.
If everything checks out you should be good to go.
