Driveshaft clarification...help!!!
I thought the double cardan WAS the cv version and was the type of d/s you want??!? Now I'm really lost. Here's how I see it, there's basically two types of d/s out there, either single cardan (single u-joint) or double cardan (two u-joints referred too as a cv at the t-case and a single u-joint at the pinion). Am I way off par here?
I'm running into the same questions but to add on more to the mix. I have a 08 2 door and I'm planning to go 35's and a 3 inch lift. Do I need to replace just the front driveshaft or both of them.
You will want to replace your front shaft at that height. The stock shaft will contact the tranny skid causing it to bust the seal, which failure soon follows. I just replaced front and rear shafts on my 2 door with RK lift. I've read and heard that the rear is fine as long as your angles are good and control arms are set properly if you have adjustable. Rear is not a necessity, front is.
Here is an idea.....Give Adams Driveshaft a call (702- 568-5680) and ask them! I mean that is their business right, building drivelines. Which they do build in house. I am local to Adams and he wheels with us all the time. He is a great guy and fellow wheeler that knows his stuff. Give him a call you will not regret it.
Or you can listen to all the armchair quarterbacks, your call.
So do I want one with replacement yokes, flange adapters, or a mix of both? Which shafts come with yokes, or flanges (Coast, Tom Woods, Adams..etc)? I'm guessing I want one with Spicer or Neapco joints, right? From what I've gathered you want to try to stay away from the flange type because it doesn't give you as much length thus increasing the angle of operation...or does it matter at all? Since I'll be running such a heavy tire/wheel combo should I run 1310 or 1350 shafts?
