Driveshaft for 6" lift
Do you have to upgrade your drive shaft after getting a 6" lift? If so any good recommendations? I have a 09 rubicon unlimited and plan on getting a 6" Teraflex long arm lift kit and running 37" tires on 17's.
Upgrade your DS. Check out Coast first. Then take a look at Woods and JE Reel.
BTW, excellent choice on the lift kit.
Here's a link to the FAQ section - it should answer all of your questions.
https://www.jk-forum.com/forums/modified-jk-tech-2/modified-tech-faq-answers-questions-every-newbie-has-18617/
By the way - sounds like a you're building kick a$$ rig - make sure to post pics once everything is installed!!
JD
TeraFlex also sells drive shafts. Send Joe a PM and he will be able to help you out.
