Driveline issue...
Old 11-20-2012, 08:03 AM
bluesteeljeep's Avatar
Default Driveline issue...
I just recently installed a coast driveline on my Aev 3.5 inch. The issue is that I get a bit of vibration over 60. Any opinions?
Old 11-20-2012, 08:06 AM
Sponsoring Vendor
Northridge4x4's Avatar
Are you using the AEV control arm Brackets?
Do you know what your castor is?
David
Old 11-20-2012, 08:11 AM
Yes I have the relocation brackets an I don't know how to measure the caster..
Old 11-20-2012, 08:28 AM
Sponsoring Vendor
To much Castor can cause a issue with the Driveline.
David
Old 11-20-2012, 09:19 AM
Shell's Avatar
From my understanding if you get a new driveshaft you need upper adjustable control arms to be able to adjust the pinion angle.
Quick Reply: Driveline issue...
