drive shaft vibrations after install
Old 04-08-2011 | 08:17 PM
  #31
animated_robot's Avatar
Originally Posted by RIver Runner
you should take it back to those so called 4x4 shops, which all of us from the area know who you prob took it to. show and tell them what you did and try to recoup some of your cash. not much of a 4x4 shop if they didn't catch that. just my thoughts
I know what you mean. It's sad that I try to do everything myself to save money, make sure it's done right, and get the learning experience - BUT when I have a problem even the (so-called) professionals don't know the answers.
I know that I made a mistake installing the drive shaft, but I agree... someone should of said, "hey did you check..."
I love this forum and everyone on here is helpful. Guess I will always leave it up to the Jeep owners for information, not the "professionals". Still though... they (4x4 shops) have helped with other things so I can't rule them out... yet.
Old 04-09-2011 | 02:20 AM
  #32
River Runner's Avatar
it is what it is, hey at least it was a learning experience that YOU figured out.
Old 04-09-2011 | 06:42 PM
  #33
Toyotafreak1965's Avatar
Originally Posted by animated_robot
Yesterday I install the Coast 1310 front drive shaft on my 3.5" lifted jeep (auto). I took it out for test run and never got any vibrations, most likely due to me driving in the neighborhood under 30 MPH.
This morning on my way to work when I hit 40+ MPH I started to get this crazy vibration that I could feel in the seat and arm rest. Also, it seems like I was getting a "humming" like sound - other than my tires.
I brought it into the shop this morning to check my caster/pinion angle and everything seems to be in specs. Any ideas? Maybe warped drive shaft?
Attachment 147401
Man I have the same Coast 1310 Front shaft(with new flanges). I have had a vibration at around 50mph ever since I first installed it. I have tried adjusting the front control arms (at one point I had the pinion pointing straight in line with the shaft) It did not cure the vibration . I couldn't drive it like that so I took it and had it lined up at a shop. The tube that the shaft was shipped in was damaged when it came in, but I didn't notice any damage to the shaft.
I also did not install it until I had the 5:38 gears installed 3 months later.
I am going to have to do something soon because I am going to drive it down to Carova Beach NC for vacation. I may have to buy a new shaft.
I just don't get it. What are these guys doing that are running 6-8 inches of lift???
Do they not drive it on the highway?
Old 04-13-2011 | 11:34 AM
  #34
Now that I have solved my drive shaft vibes. My caster is set at +1 7/8 (left) and +1 3/4 (right)
should I worry aboout this? should I get my caster back to around +4.2 ?
Old 04-13-2011 | 11:42 AM
  #35
wayoflife's Avatar
JK-Forum Founder
with caster that low, you might find that your handling on the highway will be on the flighty side of things. if not or, if you're okay with how it handles, no, you should have nothing to worry about.
Old 04-13-2011 | 11:44 AM
  #36
Thanks WOL. I did notice it a little "flighty" feeling, but manageable.
