Drive Shaft Questions
Old 05-08-2011 | 12:47 PM
matt852's Avatar
Default Drive Shaft Questions
Hey guys I was wondering if I get a TF 2.5 Coil Lift and then upgrade driveshafts, would I need to buy another set of driveshafts if I upgrade to a TF 4.0 Coil Lift or the TF Prerunner LCG system.
I've got a two door btw
Old 05-08-2011 | 02:57 PM
GunDude's Avatar
If you get 3" or more actual lift out of the kit you install you will need new shafts at some point.
Old 05-08-2011 | 04:35 PM
matt852's Avatar
Ok but I go from 3 inches of lift to 4-5 would I need to buy another new one?
Old 05-08-2011 | 05:14 PM
nthinuf's Avatar
There shouldn't be a lot of driveshaft length difference between a 3 inch lift and a 5 inch lift. Talk to the vendor to get their suggestion, or just split the difference and order one for a 4".
Old 05-08-2011 | 05:22 PM
SLVR07's Avatar
If you get one that is too long and you do not have enough slip during articulation it will break the T case.
