Drive shaft hitting gas tank
I have a rock krawler 3.5 with a je reel 1350 drive shaft and just got under the jeep after doing the rubicon and at the u joint it was hitting the tank skid enough to dig into it about .25 inches. With my stock flange it hit just a little but it is bigger. When it is just sitting on level ground it looks like I have plenty of room. And also I have the 3 link in the back. Any help would be appreciated.
JK-Forum Founder
double check to make sure that your axle is centered? more than likely, you're off a bit and when flexing on the trail, your drive shaft swings over and hits your tank. i've seen this happen a lot.
