Drive Shaft?
As said no the factory Rzeppa can run at almost any angle without vibration. the issue being the rubber boot pinching, cracking, eventually losing grease and failing. Teraflex's high angle Rzeppa kit fixes that. They even went as far as combining their joints and a HD driveshaft. Im waiting for somebody to use a TF shaft on the front of a JK with higher caster. Wonder if it will help cure vibrations people have lifted and with deeper gears.
With that said JE reel will also customize a shaft using TF's joint at the TC end with your choice at the pinion end for 1/2 the cost of TF.
Because it would put the angle at the axle over it's limitations (14*).
Run the driveshafts at whatever angle you desire as they wont give vibrations. The only reason to set the driveshaft angle with them is too ensure there's no binding if your suspension has a lot of travel.
The one thing that I've always wondered is why people use double cardans on the front. If you use a single, conventional driveshaft, running it perpendicular to the t-case output would put you at 6* of castor (6* separation between castor and pinion angle). That would seem much more desirable in my opinion.
I would imagine that if you ran a single in the front it would bind up when you flexed out the front. The front usually has more travel than the rear.
