Drift/pull to the left
Only changed two things. Replaced tie rod with RK tie rod, and got new tires, Nitto trail grapplers 35 1250. Now I have a drift/pull to the left? Is this just the tires? PSI same all around.
this happened to me when i put on my old superswampers. i just rotated the tires around and it stopped. but, i think if you were to go back, it would do the same thing (pull left)
steering wheel is straight? idk if you upgraded to bigger tires when you went to 35s. might have affected steering wheel. doubt it. but chance of it.
Set my toe with the new tie rod. My axles are slightly off centered but I guess have been for 3 years with no issues. I guess I never accounted for spring settling.
